16 years agoShifts problem on simulations of design example Cyclone II ALTLVDS (External PLL)
Dear all, I am reading SERDES Transmitter/Receiver (ALTLVDS) Megafunction User Guide. In the Design Example 2: Cyclone II ALTLVDS Using External PLL Option, both functional and timing simulati...
16 years agoHi,
In a serdes data can be misaligned. You don't know that unless you have a synchonisation mechanisme besides the serdes or use a sync pattern and the bit-slip function of the serdes. Once aligned, it stays aligned. The text coming with this example is not correct. rx_in1 receives a value of 0x01, shifted 2 bits is 0x04 rx_in2 receives a value of 0x02, shifted 2 bits is 0x08 rx_in1 receives a value of 0x06 (not 3), shifted 2 bits is 0x18 rx_in2 receives a value of 0x04, shifted 2 bits is 0x10 That's the value you see at rx_parallel_out. I don't get the TX part. First of all, tx_out3 is sent in another slow_clock period than tx_out2, tx_out1 and tx_out0. So you transmit: 00000000 00000000 04000000 00030201 00000000 Also in this timing diagram there's a phase shift between clk1 out of the PLL and slow_clock, which should the the same signal, accoring to figure 2-14 of the same document. I don't see the three position data shift, but that could be me :-) Cheers, Ton
