sda1902
2 years agoSFL problem
Hi ! In my project, I planned to use SFL to access the configuration flash, which was planned to contain not only the configuration, but also the data. Problem: The SFL project loads into the FPG...
FakhrulA_altera
2 years agoHi sda1902,
My apologies I may have overlooked this post. Here a few item you may need to check:
- Instantiate SFL IP Core Correctly:
- Ensure proper instantiation in the top-level design to connect JTAG and ASMI hard logic.
- Set Configuration Signals:
- Set noe_in to 0 to enable the SFL IP core. If not accessing ASMI externally, tie this signal to GND.
- JTAG to AS Bridge:
- Load the SFL image to bridge JTAG to the ASMI interface, crucial for programming via JTAG-ASMI.
- Shared ASMI Interface:
- Enable Share ASMI interface if sharing the ASMI interface in your design.
- Enhanced Mode SFL:
- Ensure Use enhanced mode SFL is appropriately set. For Cyclone V and Arria V devices, this parameter must be enabled.
- Programming Flow:
- After programming, reconfigure the FPGA by cycling the nConfig pin.
For further details, please refer to the provided document - AN 370: Using the Intel FPGA Serial Flash Loader.
Fakhrul
