14 years agosfixed to ufixed conversition
Hi all; I have learn about ufixed and sfixed operation. I want to convert -0.129 to sfixed using the code below and its has no problem; signal n1: ufixed (4 downto -4); ... out_A <= ...
14 years agoNow, I proceed to next stage which is multiply the conversion output with ufixed values (input).
library ieee; library ieee_proposed; use ieee_proposed.fixed_pkg.all; package my_data_types is type vector is array (natural range <>) of integer; type ufixed_array_t is array (0 to 3) of ufixed (9 downto -10); end my_data_types; library ieee; library ieee_proposed; use ieee_proposed.fixed_pkg.all; use work.my_data_types.all; entity mul_four is port (clk: in bit; A: in vector (0 to 3); out_A: out ufixed_array_t); end mul_four; architecture mul_four of mul_four is signal n1: sfixed (4 downto -4); signal n2: sfixed (n1'high + 1 downto n1'low); signal n3: ufixed (5 downto -4); signal u: ufixed (5 downto -4); begin process(clk) begin if (clk'event and clk='1') then n1 <= to_sfixed(-0.129,n1); n2 <= abs(n1); n3 <= ufixed(n2); end if; for i in 0 to 3 loop out_A(i) <= (to_ufixed (A(i),u)) * n3; end loop; end process; end mul_four; There are no error when I compile in quartus, but then an error occur in ModelSim:# Cannot continue because of fatal error. ( at line 36). Can anyone check my code?..do I write in wrong way?..need helps
