morge
1 year agoSetting vod, pre-emphasis for transceivers
Hi, I am using ARRIA10 10X066N4F40I3VG FPGA. I performed SI tests with TTK and selected the desired transceiver settings. How can I change the default transceiver parameters (vod, pre-emphasis, tap)...
Ash_R_Altera
1 year agoHi,
Can you elaborate more when you say, "I try to set the parameters in the firmware"? How are you setting the parameters? Is it using the Assignment Editor or .qsf file?
