14 years agoSetting location for PLL_x
Hi, For my design, I'm using a cyclone III /w PLL in compensated mode. So I noticed Quartus will usually automatically use the correct PLL based on the clock input if there is a single clock i...
14 years agoThank all for the replies.
--- Quote Start --- My design is the 'Block diagram/schematic file' type. Select the PLL -> right click the mouse -> Locate->Locate in Assignment Editor -> Location(Assignment name)-> PLL_x(Value) --- Quote End --- I found you can right click in the other views as well as done the same thing. I used the hierarchy and technology view the same way to automatically set the long wordy net name in the assignment editor.
