9 years agoset_input_delay And set_output_delay .SDC Constraints
Hello! I have little familiarity with the set_input_delay and set_output_delay SDC and was wondering whether the following commands would correctly constrain the inputs as per the requirements in th...
9 years ago --- Quote Start --- But even if this is right, it still doesn't explain why timing fails if I increase the output_delay_min beyond -3ns(like -4,-5 e.t.c). --- Quote End --- sorry but can you explain what you mean by "if this is right".
