9 years agoset_input_delay And set_output_delay .SDC Constraints
Hello! I have little familiarity with the set_input_delay and set_output_delay SDC and was wondering whether the following commands would correctly constrain the inputs as per the requirements in th...
9 years agoyou need to set offsets as they are:
min = 15 &max = 16 and both from falling edge. It should be no problem to pass How did get those figures of 25/10?? I needed glasses.min = t5 &max = t6 yes. If it fails then you need to try PLL or use same edge. Also you have assumed board delays to be equal for clk/data
