14 years ago
set D.F during reset
Is it possible to set signals to different value other then 0 during the reset time?
For instance:
"if reset='1' then
pwm_count <=12; -- integer, is it allow?
PWM_Hex_CMD_Sample <=x"7F"; --std_logic_vector, is it allow?
Default_Num <= '1'; -- std_logic, is it allow?
Positive_Edge <= '0';
Negative_Edge <= '0';
elsif clk'event and clk='1' then"
The target is Cyclone III, EP3C25F324.
Idan :rolleyes:
1 Reply
    --- Quote Start ---
    --- Quote End ---
    Yes, you can set signals and registers to specified values at both power-on and on reset.
    Eg., power-on signal value:
    signal data : std_logic_vector(7 downto 0) := X"56";
    Eg., reset signal value:
    process(clk,rstN)
    if (rstN = '0') then
        data <= X"78";
    elseif rising_edge(clk) then
    If you simulate this pair of conditions, and rstN is high at the start of the simulation, then the data value will be X"56". When you assert reset, data will change to X"78".
    The same thing happens in hardware. If your hardware only supports registers that reset to zero, then Quartus will implement not-gate push back, i.e., put inverters on the input and output of the registers to make the register reset zero, but your signal one.
    --- Quote Start ---
    --- Quote End ---
    It depends on what the definition of pwm_count is. If its an unsigned, then sure, no problem. If its an integer, then it would also be ok, however, you'll want to make sure its an integer with a constrained range for synthesis.
    Cheers,
    Dave
