11 years agoSet configuration with PS mode by other MCU
Hello, I have some problems with PS mode configuration. I used to use AS mode as configuration solution for years. And this time , I want to config the FPGA with other MCU with PS mode. ...
11 years ago --- Quote Start --- There is something odd among the waveform. The CONF_DONE raised before the last byte of .rbf was sent. It's different form the document. --- Quote End --- If you look at figure 1 in the document I linked to, CONF_DONE goes high, and then if you have enabled it, INIT_DONE. If you read the data sheet for the device you are using, there is sometimes a note about sending additional clocks after CONF_DONE goes high, so that the device enters "user mode". Those extra clocks are implemented as extra bytes in the .rbf file, so when you trace configuration of an FPGA, you will see DCLK continue after CONF_DONE asserts. Look at the logic analyzer traces in Figure 31 on p60 - note how the FPGA configuration data bus goes to FFh, but DCLK continues to toggle, and then CONF_DONE asserts. In other devices, it might be that CONF_DONE asserts before DCLK stops toggling. I would not be concerned if that is what you are seeing. The main thing is that if CONF_DONE has asserted, your FPGA is configured correctly. Cheers, Dave
