11 years agoSerializing Avalon-ST over XCVR for FPGA-to-FPGA Transmission
I would like to know what options are available for serializing Avalon-ST video data over high-speed XCVR for tranmission between two FPGAs with lowest latency? I have a set of HD resolution video in...
11 years agoHi,
The mode of XCVR to use will be depending on your target data rate, interface width, refclk and etc. If you are looking for a ready-make solution, you can try to look into Altera IP cores ie SDI IP and etc to see if can find one that suit you.
