19 years agoSerial FlashLoader
So I've got Quartus 7.1 and have created the Serial FlashLoader module... now what? Does anyone have an example of how to instantiate the Serial FlashLoader. Please do not direct me to AN370. I...
19 years agoHi Rob,
are you sure you need to use the Serial FlashLoader? Are you using a EPCS device as serial configuration device? I also refered to the documentations of Altera and thought I need one to use the EPCS device with JTAG, but then I saw the post "Write the project in EPCS?" in the Nios forum under "General Discussion Forum". Check it out, maybe this is also true in your case?!
