19 years agoSerial FlashLoader
So I've got Quartus 7.1 and have created the Serial FlashLoader module... now what? Does anyone have an example of how to instantiate the Serial FlashLoader. Please do not direct me to AN370. I...
19 years agoI would recommend filing a Service Request on the Altera support site https://mysupport.altera.com/eservice/ when you encounter an issue such as this. The workaround appears to be setting the Configuration Pins to "Use as Regular I/O" and this will get you past the fitter. Some internal settings are conflicting and this will most likely be addressed in a future service pack.
Make the settings here: Menu Item "Assignments", "Settings", "Device" sections, click on the "Device & Pin Options" Button, Dual-Purpose Pins tab, set all of these pins to "Use as Regular I/O". This will allow the fitter to map the serial loader pins to dclk, ncso, data0, asdo to be the same as the ones connected to the Active Serial configuration device. I have attached an example Verilog implementation of this. This is for Quartus v7.1.
