15 years agoSerial Flash Loader beside Differential IO
Hi Guys! I am using an Cyclone III which has an AS-Device attached to it - on a nearby pin an LVDS signal is generated. To program the configuration device, I would like to use Altera's Serial ...
15 years agoI tried to implement the maximum toggle frequencies as suggested by kbs982's posting, but it didn't work.
However, by incidence I found at the SFL-instance the following pins: SFL:inst|altserial_flash_loader:altserial_flash_loader_component|\GEN_ASMI_TYPE_1:asmi_inst~ALTERA_DCLK SFL:inst|altserial_flash_loader:altserial_flash_loader_component|\GEN_ASMI_TYPE_1:asmi_inst~ALTERA_SCE SFL:inst|altserial_flash_loader:altserial_flash_loader_component|\GEN_ASMI_TYPE_1:asmi_inst~ALTERA_SDO SFL:inst|altserial_flash_loader:altserial_flash_loader_component|\GEN_ASMI_TYPE_1:asmi_inst~ALTERA_DATA0 When I entered them in the Assignment Editor, everything was working fine. Thanks for your help anyway!
