15 years agoSerial Flash Loader beside Differential IO
Hi Guys! I am using an Cyclone III which has an AS-Device attached to it - on a nearby pin an LVDS signal is generated. To program the configuration device, I would like to use Altera's Serial ...
15 years ago~ALTERA_DCLK~ would be the pin name. Pretty sure that should be enough to get you to the 0MHz setting. If not, configure it as a regular io pin and then drive it to ground(or VCC, don't know which is best), then hit the 0MHz setting to that pin name.
Hope this helps. Kevin
