15 years agoserial async transmit
hi all
here is my problem... i would like to connect range sensor to DE2 kit to show results of the range.. the TX output delivers asynchronous serial with an RS232 format, except voltages are 0-Vcc. The output is an ASCII capital “R”, followed by three ASCII character digits representing the range in inches up to a maximum of 255, followed by a carriage return (ASCII 13). The baud rate is 9600, 8 bits, no parity, with one stop bit i wrote this code just trying to read the first character "R": --- Quote Start --- library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; use work.components.all; entity sonar is port ( din,rst : in bit; clk : std_logic; data : out bit_vector (7 downto 0); data_valid : out bit ); end sonar; architecture rtl of sonar is signal sample:std_logic; signal s:std_logic:='1'; begin m:sampler port map (clk,sample); // dividing the freq// process (rst , sample) variable count: integer range 0 to 10; // start+8 data+stop bits // variable reg: bit_vector (10 downto 0); begin if s<='1' then // to make sure the code will be excuted one time// if (rst='1') then count:=0; reg:=(reg'range =>'0'); data_valid <='0'; elsif (sample'event and sample='1')then if (reg(0)='0'and din='1')then reg(0):='1'; elsif (reg(0)<='1') then count:=count+1; if (count<10) then reg(count):= din; elsif (count=10)then count:=0; data_valid <='1'; data<=reg(8 downto 1); end if; end if; end if; end if; s<='0'; end process; end rtl; --- Quote End --- and this is my sampler --- Quote Start --- library ieee; use ieee.std_logic_1164.all; ------------------------------ entity sampler is port ( clk: in std_logic; sample: out std_logic); end sampler; ------------------------------ architecture sam of sampler is begin process (clk) variable counter: integer range 0 to 5000:=0; begin if (clk'event and clk='1') then if (counter=5000) then counter:=0; end if; counter:=counter+1; if (counter>=4999) then sample<='1'; else sample<='0'; end if; end if; end process; end sam; --- Quote End --- and this is my component --- Quote Start --- component sampler is port (clk: in std_logic; sample: out std_logic); end component; --- Quote End --- after programing i got this result data='11111111' could anyone tell me what's wrong?! where is my fault!!2 Replies
--- Quote Start --- A UART receiver would be expected to oversample the input and synchronize on a start bit. I can't detect this in your code. --- Quote End --- what do you suggest? --- Quote Start --- Using a divided ("ripple") clock has the disadvantage of causing timing conflicts when transfering the UART output to other design parts. The synchronous clock enable method would be preferred. --- Quote End --- in my code....is there a problem with synchronisation? thanx FvM. - Altera_Forum
