15 years agoserial async transmit
hi all here is my problem... i would like to connect range sensor to DE2 kit to show results of the range.. the TX output delivers asynchronous serial with an RS232 format, except voltages...
15 years agoA UART receiver would be expected to oversample the input and synchronize on a start bit. I can't detect this in your code.
Using a divided ("ripple") clock has the disadvantage of causing timing conflicts when transfering the UART output to other design parts. The synchronous clock enable method would be preferred.
