15 years agoserial async transmit
hi all here is my problem... i would like to connect range sensor to DE2 kit to show results of the range.. the TX output delivers asynchronous serial with an RS232 format, except voltages...
15 years ago --- Quote Start --- A UART receiver would be expected to oversample the input and synchronize on a start bit. I can't detect this in your code. --- Quote End --- what do you suggest? --- Quote Start --- Using a divided ("ripple") clock has the disadvantage of causing timing conflicts when transfering the UART output to other design parts. The synchronous clock enable method would be preferred. --- Quote End --- in my code....is there a problem with synchronisation? thanx FvM.
