11 years agoSequential Switching
I am trying to develop a sequencer digital circuit in VHDL and implement it on a DE 1 dev board although I have hit a wall. I have done a signal tap of the output of my FPGA although when I take a lo...
11 years agoDid you check if you had a short circuit between TX2 and TX3? You can generate a simple FPGA project that drives both pins to different signals (for example 0 for TX2 and 1 for TX3) and check the output with the digitizer.
