9 years agosending 64 bit from fpga to hs to terminal in pc @10k
hi, i had a terasic sockit (which had a cyclone 5 soc). i already implemented sending 64 bit data from fpga to pc by using nios2 processor ( nios2+jtag uart_onchipram). but its speeed is very ...
8 years agoHI,
i had completed the qsys system and sending the bits from fpga to hps using light-weight-hps to fpga bridge. but my problem is how can i access the number in c code. which is the part of the hps. how will i get the numbers in c code from the bridge. can anybody give some suggestion(. in lightweight bridge and htof axi bridge ) any help will be really appreciated. thanks and regards
