16 years agoSDRAM on DE2-70
Hi all I tried to use SDRAM in nios II but no result In sopc I used PLL with 100 MHZ for system clock and I used 100 MHZ with -3 ns for SDRAM controller. In Nios II IDE i tried to use IOWR_...
16 years ago115200 kbit/sec is far away from too high, 921600 kbit/sec with a normal pc uart is no problem IF you use hardware handshake RTS & CTS and FIFO's to enshure that the transmission is stalled when the data can't be processed in "realtime"
