16 years agoSDRAM on DE2-70
Hi all I tried to use SDRAM in nios II but no result In sopc I used PLL with 100 MHZ for system clock and I used 100 MHZ with -3 ns for SDRAM controller. In Nios II IDE i tried to use IOWR_...
16 years agoThanks alot.
All things is going OK.:) Now I want to load Image from PC to SDRAM. Is there a way that I load this Image without convert it to numbers. Beacuse in NIOS II IDE i copied Image in the project folder when double click it opend in the IDE such as using of Paint in windows. If not, Could you aadvice me the best and fastet way to load data from PC, for example by using UART or fopen,fread......, or what? B.regards.
