15 years agoSDRAM for Image Processing
HI... I'm working on an image processing system and everything goes fine, but when i read my data out from the sdram i receive a lot of garbage data... then two big vertical lines appeared in m...
15 years agoParva,
I think you can run modelsim. But you must have a physical hardware to be able to run it sdram. Sean
