15 years agoSDRAM for Image Processing
HI... I'm working on an image processing system and everything goes fine, but when i read my data out from the sdram i receive a lot of garbage data... then two big vertical lines appeared in m...
15 years agohi...
i double checked pin assigment,it seems to be correctly assigned.Since i making neighborhood inspection, using differents offset to read the sdram, my problem could be related to one of thee issues? the thing is that i dont understand the proposed solution :confused: problemWhy does the Scatter-Gather DMA (SG-DMA) Controller Core stall indefinitely if burst transfers are enabled? solution The SGDMA will stall indefinitely if it encounters transfer lengths which are not multiples of the burst length. This will only occur if burst transfers are enabled. For example if you configure the SGDMA for 32 bit transfers with a maximum burst length of 2 then you must use transfer lengths that are multiples of eight bytes to avoid this issue. To avoid this issue please upgrade to the Quartus II design software version 8.1 and regenerate your system in SOPC Builder. problem Why do I get corrupt data read results with the Scatter-Gather DMA Controller Core (SG-DMA)? solution If you enable unaligned accesses, read data can become corrupt. To avoid this you should disable unaligned accesses and only provide word aligned read addresses to the SGDMA. thank you
