15 years agoSDRAM for Image Processing
HI... I'm working on an image processing system and everything goes fine, but when i read my data out from the sdram i receive a lot of garbage data... then two big vertical lines appeared in m...
15 years agoMake sure double check your pin assigments and your clk pin to sdram too. The simple is using SGDMA.
Sean
