10 years agoSDRAM Clock
Hi, I use SDRAM controller to connect FPGA and SPANSION(167 MHz) SDRAM. Nios II processor run up to 100 MHZ clock and I can not use higher frequency. I did not use dedicated PLL FPGA pin for S...
10 years agothanks Mr. Cris72. How can I use on_chip_memory for 140MHz clock? can I select different clock for processor and memory in the Nios System?
Regards.
