SDR SDRAM Controller MAX II
Hey guys,
iam trying to Interface an SDR SDRAM from Micron with a MAX II CPLD.
Iam able to read between 10 - 400 Adresses but then i think because of timing issues the Read fails...
Because iam using an MAX II iam not able to get a PLL for the SDRAM Clock.... are there any reliable ways to Phase Shift the SDRAM Clock without a PLL ? Or does someone can give me tipps to constraint my Design with a Zero Phase shift ?
Currently iam driven the Controller and SDRAM with the same 100 Mhz clock from an external oscillator.
SDRAM : Micron MT48LC4M32B2B5-7 Max II : EPM1270
- MFric2
Hey,
it has turned out that my sdram controller wont take care if there is a read request at the same time with an automatic auto refresh command so they overlap... which obviously fails
- a_x_h_75
Contributor
Are you issuing refresh cycles regularly enough? The fact you can successfully read something suggests to me it might not be a timing issue...
Cheers,
Alex
- NurAida_A_Intel
Hi Sir,
You can try to constraint the output clock from the FPGA using generated clock constraint as explain in this link:
Hope this is helpful.
NAli1
