SDI output transmitter with 2 standards
- 3 years ago
We were not properly managing tx_datain_valid signal for triple rate.
The easyest way to do it is to drive tx_dataout_valid directly to that imput.
Now we can switch between standarts perfectly.
Thanks for your support
Hi RD-FD,
Thank you for your patience.
For Cyclone V device, the SDI II IP do support triple-rate design.
Allow me to confirm with you below items:
Q1. Is your project based on design example?
Q2. If yes, did you generate the design in single-rate 3G or triple rate?
Triple-rate supports switching between 3G-SDI, HD-SDI, and SD-SDI.
Based on your case description, it seems like you are generating single-rate 3G, which will cause switching to HD-SDI result in no display. You may generate a triple-rate design to support your project.
Hoping to hear back from you so that we can proceed for next step.
Thank you.
ZulsyafiqH_Intel
