11 years agoSDI II IP Core to implement HD-SDI 720p Digital Video
Hello, I am looking into HD-SDI 720p Digital Video and using the SDI II IP Core. If anyone has used this IP core or has implemented an HD-SDI digital video source can you please let me know your expe...
11 years agoIf only TX is needed, it would be easy. RX multi-rate is a bit complicated against TX because dynamic transceiver reconfiguration is required. This example designs would help you.
http://www.alterawiki.com/wiki/triple-rate_sdi_ii_simple_design
