15 years agoSDC problem
Hi, i want to implement a SoC with the maximum frequency of my board StratixIV Gx. I used one pll with two output, first output pll.c0=150Mhz, second output is 125Mhz. After a compilation and...
15 years ago --- Quote Start --- If it closes timing at 250MHz, then from a static timing analysis perspective it will work. As for accelerating the design, there are many things but all design specific. I won't really be able to provide any guidance there. --- Quote End --- Ok thank you,
