15 years agoSDC problem
Hi, i want to implement a SoC with the maximum frequency of my board StratixIV Gx. I used one pll with two output, first output pll.c0=150Mhz, second output is 125Mhz. After a compilation and...
15 years ago --- Quote Start --- You need to constrain your clocks. Read the documentation for TimeQuest. Download Rysc's document from the Altera Wiki and read that. Cheers, Dave --- Quote End --- Think you very much for your help, i will read the documentation,:)
