15 years agoSDC problem
Hi, i want to implement a SoC with the maximum frequency of my board StratixIV Gx. I used one pll with two output, first output pll.c0=150Mhz, second output is 125Mhz. After a compilation and...
15 years ago --- Quote Start --- 2-warning: node: clk_inp was determined to be a clock but was found without an associated clock assignment. 3-warning: node: clk_0 was determined to be a clock but was found without an associated clock assignment. 4critical warning: timing requirements not met.
--- Quote End --- You need to constrain your clocks. Read the documentation for TimeQuest. Download Rysc's document from the Altera Wiki and read that. Cheers, Dave
