16 years agoSDC FIle
HI, Can I use two .sdc files.... in different folders.... Let us say I have two folders 1) Base_clock 2)Derived Clock In the folder named "Base_clock" I keep all the settings for ba...
16 years agoI have no expertise in 'tcl command flow' ...
You can also manually add the two .sdc files in the project's .qsf file using e.g. set_global_assignment -name SDC_FILE file1.sdc set_global_assignment -name SDC_FILE file2.sdc
