Vic3Dexe
4 years agoSDC constrains for async static RAM
I have async static RAM with 10 ns access time.
I try to read data from it in such a way, that address formed in one register, then data latched to another, both have the same clock 50 MHz (20 ns)....
Vic3Dexe
4 years agoIn your example you have md assigned twice, is it ok?
assign md = mr & mrd ? mdo : {12{1'bz}}; ... assign md = mr & ~mw & enb_ext ? ext_dq : {12{1'bz}};
And mdo is actually read from internal memory, not external
always @(posedge clk) begin if (mwr) memory[addr] <= #TPD mdi; mdo <= #TPD memory[addr]; end
while data from external (as far as I understand) is not registered, md lines are just output of the module
assign ext_dq = mw & ~mr ? mdi : {12{1'bz}}; assign md = mr & ~mw & enb_ext ? ext_dq : {12{1'bz}};
So it's not my case, my problem starts when I try to register md lines.
And in these lines
set_input_delay -clock CPUCLK -max 10.0 [get_ports {SRAM_DQ[*]}] set_input_delay -clock CPUCLK -min 3.0 [get_ports {SRAM_DQ[*]}] set_multicycle_path -from [get_ports {SRAM_DQ[*]}] -rise_to CPUCLK -setup 2 set_multicycle_path -from [get_ports {SRAM_DQ[*]}] -rise_to CPUCLK -hold 2
10 and 3 are what? Ok, lets assume 10 is 10 ns access time. So what is 3? Hold time? Why 3? Shouldn't it be negative?
Multicycle is 2... why? In your code you set address at negedge and latch data at posedge (lets assume you read external RAM). Isn't it all counts as only 1 cycle?
Same in these lines
set_output_delay -clock CPUCLK -clock_fall -max 4.0 [get_ports {SRAM_*_L SRAM_A[*]}] set_output_delay -clock CPUCLK -clock_fall -min 0.5 [get_ports {SRAM_*_L SRAM_A[*]}]
where 4 and 0.5 comes from?
I appreciate for helping, but I want not only copy-paste, I want to understand what I copypasting )
