9 years agoSD card multiple read
Hello everyone Greetings, I am Ph.D student working on FPGA, I am facing a problem that I couldn't figure out its reason(s). I have implemented SD card reading / writing. The prob...
9 years agoDear Tricky, you can name it a gap in knowledge , may be , because I had implemented many circuits before as SDHC, wavelet and VGA... I show the error in this code because it was the same when I used the SRAM in code below .
IF (wr_done='0') THEN wr_enable := clk; test <= D(7 DOWNTO 0); A <= std_logic_vector(to_unsigned(i,18)); ELSE test <= D(7 DOWNTO 0); A <= std_logic_vector(to_unsigned(vac,18)); wr_enable := '1'; END IF; nWE <= wr_enable; wdone_test <= wr_enable; --Bidirectional bus:-------------- IF (wr_enable='0') THEN D <= "00000000" & myram(i); ELSE D <= (OTHERS => 'Z'); END IF; END PROCESS; END ARCHITECTURE; here when I replaced myram with SD data I got the same error. And the code above worked well with VGA and images are shown correctly and the ram is created. If I had a problem with basics it wouldn't run eventually. However if you think it is a basic question , I wish you guide me to what to read to pass it. Thank you With my best regards.
