10 years ago
SD card interface
I want to add a SD card reader to the hardware of a cyclone3. I have the JTAG/ISP SPI interface wired out.
If the system is booted from flash, can I bolt a SD card reader to the programmer interface somehow? (for FAT)
Or do I need more pins?
    If you set these dual-purpose pins as "Use as regular I/O" in the Quartus project settings, you can use them like any other I/O pin.
    The configuration file instructs the fpga to initialize them in the orrect way.
    After this, is up to your design to control them for your specific purpose.
    --- Quote Start ---
    FlashNCE and data pins are dual purpose pins and they can indeed be used as GP I/O pins.
    You have to set them as generic I/O in the device configuration assignments
    --- Quote End ---
    Ok, so you would program those with the file?
    --- Quote Start ---
    If you mean the jtag pins (tck, tms, ...) the answer is No. Those are dedicated pins and you can't use them. You need to wire out any other general purpose I/Os.
    --- Quote End ---
    Yes, and the FlashNCE, and data pins.. Thanks for the reply!
