20 years ago
SD Card controller
You can achive this core if you'd like, good luck!
small error, delete fifo_buffer.v in class.ptf in line:
verilog_synthesis_files = "crc_unit_7.v,fifo_buffer.v,sd_controller.v,sd_host.v";
This core is working as master in the same time and writing read data to memory directly.
    --- Quote Start ---
    originally posted by pakolg@Nov 28 2006, 06:40 PM
    i have a ?? for sd card i have only have to put the core inthe fpga?? im ussing cyclone2 because im trying to fin a wait to put data in the sd card...and do u have to use
    ulinux??
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19668)
    --- quote end ---
    --- Quote End ---
    In this version was realized just reading. You may use it for uclinux for reading SD but you should write some drivers for this OS.
    i have a ?? for Sd card i have only have to put the Core inthe FPGA?? im ussing Cyclone2 because im trying to fin a wait to put data in the SD card...and do u have to use
    ulinux??
