20 years agoSD Card controller
You can achive this core if you'd like, good luck! small error, delete fifo_buffer.v in class.ptf in line: verilog_synthesis_files = "crc_unit_7.v,fifo_buffer.v,sd_controller.v,sd_...
19 years ago --- Quote Start --- originally posted by pakolg@Nov 28 2006, 06:40 PM i have a ?? for sd card i have only have to put the core inthe fpga?? im ussing cyclone2 because im trying to fin a wait to put data in the sd card...and do u have to use
ulinux??
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19668)
--- quote end ---
--- Quote End --- In this version was realized just reading. You may use it for uclinux for reading SD but you should write some drivers for this OS.
