Jeremy_S's avatar
Jeremy_S
4 years ago
Script hangs when attempting command, no error message
The command:
link_project_to_device -device_name {1SG166HN1(.|AS|BK)|1SG166HN2|..@2#USB-1}
causes the script to hang indefinitely and not provide an error message. This occurs with Quartus v 20.4, however it works as intended with Quartus v 19.3.
Ultimately we need this script to work with 20.4. Any insight is appreciated.
  • Farabi_Altera's avatar
    Farabi_Altera
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    regards,
    Farabi
    Farabi_Altera
    I need more information :
    1. if using GUI from quartus programmer, can it programmed? this is to filter out hw issues.
    2. when it can program successfully at 19.3 meaning is it working at the same board or different board?
    regards,
    Farabi
  • Nurina's avatar
    Nurina
    You may try reduce the TCK frequency of the USB Blaster II (16MHz or 6MHz) if you are using it.
    Nurina
    • Jeremy_S's avatar
      Jeremy_S
      Greetings,
      We currently use 16 MHz for everything. Is there a reason 16 MHz would work with Quartus 19.3 but not 20.4?
      Jeremy
