Jeremy_S
4 years agoScript hangs when attempting command, no error message
The command:
link_project_to_device -device_name {1SG166HN1(.|AS|BK)|1SG166HN2|..@2#USB-1}
causes the script to hang indefinitely and not provide an error message. This occurs with Quartus v 20....
Nurina
4 years agoHi,
You may try reduce the TCK frequency of the USB Blaster II (16MHz or 6MHz) if you are using it.
Nurina
- Jeremy_S4 years ago
Greetings,
We currently use 16 MHz for everything. Is there a reason 16 MHz would work with Quartus 19.3 but not 20.4?
Jeremy
