14 years agoSample synch. signal with unknown phase shift
Hi All, I have a following problem. I have two devices (Transmitter and receiver). Both devices have a synchronous clock with unknown phase. The distance of the devices is about 300m and they ...
14 years agoDear Rysc, FvM
Most of the comments are right but they are exactly the source of my problem. Let's go step by step: 1) Data rate is clear 40MBd (modulation frequency)* 192 (number of bit)=> 7.68GB and you have to think about them as a group and raw data it is just a vector of the pulses. Also needed skew is 0 I have to identify the pulse with one clock cycle precision. 2) the problem of the optical fiber (which we have in parallel) is that delay is about 5ns/m also serialisation and deserialisation takes some time and I have a limited time when I have to receive the information. With the optics I am a few clock cycles late for several cases of the applycation. This also gives the answer about limited number of the clock cycles. I have to do some calculations too and I really dont have much time. 3) I have also problem if I kick the D flip flop and I put it metastable state for a few clock cycles this can generate extreme problem if it happens often. This is why I have put this post here. I am thinking about it and I don't have much options. If you are interrested in more details I can send you an email to explain the project. so the problem is clear I have to be fast and prevent met. state
