14 years agoSample synch. signal with unknown phase shift
Hi All, I have a following problem. I have two devices (Transmitter and receiver). Both devices have a synchronous clock with unknown phase. The distance of the devices is about 300m and they ...
14 years agoI would use a phase-compensation FIFO. Since you have no idea what the phase is, they work quite well. You could probably make the offset 2 and have it work fine. Just make sure you release the reset once the clocks are stable. I've attached something I wrote up.
You could probably do something to detect the latency through and reduce it when it ends up being the high-end, or something like that, but I've never seen anyone do that.
