16 years agoSame logic high ,but different voltage
Hi,guys. So why different pins have different voltage, while they are all logic high. (In my experiment,one is 1.14V, the other is 3.3V) Appreciate for any reply
16 years agoDid you notice, that the said pin (signal proto5_IO37) is also connected to the CF socket? Busswitch U22 is connected between the GPIO connector (proto5_IO37) and the FPGA (proto_IO37). If the problem persists, you should measure both sides of U22.
