MWeng3
6 years agoS10 ddr4 controller Internal Error Sub-system: OCT Line 2587
synthesis crashes please help!!! : Problem Details Error: Internal Error: Sub-system: OCT, File: /quartus/periph/oct/oct_gen6_read_assignments.cpp, Line: 2587 rzq_pad_atom != NULL Stack Trace: ...
BoonT_Intel
6 years agoHi Sir, Is this KDB will help?
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/tools/2019/internal-error--sub-system--oct--file---quartus-periph-oct-octge0.html
MWeng3
6 years agothank you, I tried versions 18.0, 18.1, 19.1 and 19.3 all crash.
- BoonT_Intel6 years ago
Is your design have PR.If not then the the KDB might not related.
can you share more details on your design. Is the design is generated example design? or custom design using the DDR4 IP?
From the error message, its looks like there are some problem on the RZQ pin. Is your design have any special constraint to this pin? Maybe you can remove all the pin assignment (location, I/O standard, termination) of this pin and try to recompile?
