15 years agoRunning microC/OS-II from onchip memory
I have a Quartus 10.1 SOPC design with a nios2 running out of on chip memory. The nios2's reset vector points to the onchip memory with offset 0x0. The exception vector points to a separate onchip me...
15 years agoThe errors I was getting were because I had commented out OSStart in the main. It is working now the problem was the BSP settings. Most likely is the 'allow_code_at_reset' option. Thanks for your help.
