run hello world in custom rootFS for agilex"
Looking for HPS Linus steps to add C Hello world and adding binaries/precompiled utilities to Linux rfs.
- EBERLAZARE_I_Intel
First step for the gitclone you do this instead of the mentioned step:
$ git clone -b kirkstone https://github.com/altera-opensource/gsrd-socfpga
Then continue as normal including this:
you can modify the recipe in: recipes-images/poky/gsrd-console-image.bb
- add your c file in recipes-images/poky/files (mkdir)
- In recipes-images/poky/gsrd-console-image.bb, add the followings
- FILESEXTRAPATHS:prepend := "${THISDIR}/files:"
- SRC_URI:append = " <CFILE>"
- Add this under nfs_rootfs() function:
- cp ${WORKDIR}/<CFILE> ${IMAGE_ROOTFS}/home/root
Then continue step 4. (build_setup) and until bitbake and package in the Custom GSRD steps :
- MK_086
Thanks for the detailed steps.
We will get access to this compilation setup after a week. Will share the results after that, thanks for your patience.
My apologies for the very late responds I was able to locate the "files" folder in Linux.
Are you able to run bitbake and build package from your side?
- MK_086
Glad to hear about this. No, our trails didn't work much as shared in my thread.
Could you please share the steps and solution for this?
I will have the test this week on our board, might take some time, I already finish the build.
I will let you know the result after, thanks for your patience.
- KennyT_altera
Kindly note that there will be some slowness on the first reply due to the public holiday, we will get back to you as soon as possible.
