11 years agoRun demonstrations in DE1-SoC board
I have bought a DE1-SoC board and got a problem, which is showed in the included image, when I have tried to run the batch file in FPGA project contained in the DE1-SoC System CD. https://www.alteraforum.com/forum/attachment.php?attachmentid=10903 Can anyone have ideas as how to solve this problem? Thanks!3 Replies
Thank you for replying! I have no problem with USB blaster. I can also download a FPGA SRAM Object File, but I am not able to run the batch file.
Thank you for replying! I have no problem with USB blaster. I can also download a FPGA SRAM Object File, but I am not able to run the batch file in demonstrations.
http://i.imgur.com/n3vaSnL.png http://i.imgur.com/lPAp3e3.png - Altera_Forum
Seems like no Altera USB blaster issue.
Do you have your QII software installed? The QII installation should come with the Altera USB driver. You can try check your Altera USB blaster is working or not through the QII programmer. Make sure your usb cable is connected :p
