9 years agors232 uart ip :: user guide
hi, // unnamed.v
// Generated using ACDS version 16.0 211
`timescale 1 ps / 1 ps
module unnamed (
input wire address, // avalon_rs232_slave.address
input wire chipselec...
9 years agoNo - you don't need any C code to send characters to the UART.
However, you mention a 'Hello World' program as your 'reference'. This will be in C and will be for use on, typically, a Nios processor core. So, I'm a little confused as to what you're trying to do. You can either connect the UART IP directly in your Verilog - as you showed in your first post (no c code required), or you connect the UART IP to a Nios soft processor, via Avalon, and run software (C code) on the Nios - which is where the 'Hello World' programs comes in. Which one are you're trying to do? Cheers, Alex
