9 years agors232 uart ip :: user guide
hi, // unnamed.v
// Generated using ACDS version 16.0 211
`timescale 1 ps / 1 ps
module unnamed (
input wire address, // avalon_rs232_slave.address
input wire chipselec...
9 years agohi,
thanks much for the information Alex, do i really need a "C' code to send the data to pc, I am taking default "hello world program as my reference". so i am confused , because if i need a C code , then how i will transfer output of verilog code to c code to print it in pc ? i mean how to connect verilog code and c code? else after generating the qusy system ( nios II + on chip ram + rs 232 uart) , can i connect it directly using verilog & then transfer to putty ? thanks and regards update :::::::::::::::: basically if "" output [7:0] x_out " is my output register how can i access it using c code (if we need c code for this ). thanks in advance
