9 years agors232 uart ip :: user guide
hi, // unnamed.v
// Generated using ACDS version 16.0 211
`timescale 1 ps / 1 ps
module unnamed (
input wire address, // avalon_rs232_slave.address
input wire chipselec...
9 years agoChapter 7 of the "embedded peripherals ip user guide (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_embedded_ip.pdf)".
Your 'address' wire input will need to be a little wider... If you want to connect only part of a bus to a narrower signal you can always specify the bits of the bus you wish to connect. e.g..writedata (writedata), // .writedata Cheers, Alex
