13 years ago
ROM contents confusion
Hai,
I have vhdl code for store a constant in ROM. The ROM is divided into odd and even; ROMO and ROME as shown below:
library IEEE;    use IEEE.STD_LOGIC_1164.all;  --  use ieee.STD_LOGIC_signed.all;    use IEEE.STD_LOGIC_arith.all;   use WORK.MDCT_PKG.all;  entity ROMO is    port(         addr         : in  STD_LOGIC_VECTOR(ROMADDR_W-1 downto 0);        clk          : in  STD_LOGIC;                  datao        : out STD_LOGIC_VECTOR(ROMDATA_W-1 downto 0)    );              end ROMO;   architecture RTL of ROMO is     type ROM_TYPE is array (0 to 2**ROMADDR_W-1)              of STD_LOGIC_VECTOR(ROMDATA_W-1 downto 0);   constant rom : ROM_TYPE :=      (        (others => '0'),        conv_std_logic_vector( GP,ROMDATA_W ),        conv_std_logic_vector( FP,ROMDATA_W ),        conv_std_logic_vector( FP+GP,ROMDATA_W ),        conv_std_logic_vector( EP,ROMDATA_W ),        conv_std_logic_vector( EP+GP,ROMDATA_W ),        conv_std_logic_vector( EP+FP,ROMDATA_W ),        conv_std_logic_vector( EP+FP+GP,ROMDATA_W ),        conv_std_logic_vector( DP,ROMDATA_W ),        conv_std_logic_vector( DP+GP,ROMDATA_W ),        conv_std_logic_vector( DP+FP,ROMDATA_W ),        conv_std_logic_vector( DP+FP+GP,ROMDATA_W ),        conv_std_logic_vector( DP+EP,ROMDATA_W ),        conv_std_logic_vector( DP+EP+GP,ROMDATA_W ),        conv_std_logic_vector( DP+EP+FP,ROMDATA_W ),        conv_std_logic_vector( DP+EP+FP+GP,ROMDATA_W ),                   (others => '0'),        conv_std_logic_vector( FM,ROMDATA_W ),        conv_std_logic_vector( DM,ROMDATA_W ),        conv_std_logic_vector( DM+FM,ROMDATA_W ),        conv_std_logic_vector( GM,ROMDATA_W ),        conv_std_logic_vector( GM+FM,ROMDATA_W ),        conv_std_logic_vector( GM+DM,ROMDATA_W ),        conv_std_logic_vector( GM+DM+FM,ROMDATA_W ),        conv_std_logic_vector( EP,ROMDATA_W ),        conv_std_logic_vector( EP+FM,ROMDATA_W ),        conv_std_logic_vector( EP+DM,ROMDATA_W ),        conv_std_logic_vector( EP+DM+FM,ROMDATA_W ),        conv_std_logic_vector( EP+GM,ROMDATA_W ),        conv_std_logic_vector( EP+GM+FM,ROMDATA_W ),        conv_std_logic_vector( EP+GM+DM,ROMDATA_W ),        conv_std_logic_vector( EP+GM+DM+FM,ROMDATA_W ),               (others => '0'),        conv_std_logic_vector( EP,ROMDATA_W ),        conv_std_logic_vector( GP,ROMDATA_W ),        conv_std_logic_vector( EP+GP,ROMDATA_W ),        conv_std_logic_vector( DM,ROMDATA_W ),        conv_std_logic_vector( DM+EP,ROMDATA_W ),        conv_std_logic_vector( DM+GP,ROMDATA_W ),        conv_std_logic_vector( DM+GP+EP,ROMDATA_W ),        conv_std_logic_vector( FP,ROMDATA_W ),        conv_std_logic_vector( FP+EP,ROMDATA_W ),        conv_std_logic_vector( FP+GP,ROMDATA_W ),        conv_std_logic_vector( FP+GP+EP,ROMDATA_W ),        conv_std_logic_vector( FP+DM,ROMDATA_W ),        conv_std_logic_vector( FP+DM+EP,ROMDATA_W ),        conv_std_logic_vector( FP+DM+GP,ROMDATA_W ),        conv_std_logic_vector( FP+DM+GP+EP,ROMDATA_W ),             (others => '0'),        conv_std_logic_vector( DM,ROMDATA_W ),        conv_std_logic_vector( EP,ROMDATA_W ),        conv_std_logic_vector( EP+DM,ROMDATA_W ),        conv_std_logic_vector( FM,ROMDATA_W ),        conv_std_logic_vector( FM+DM,ROMDATA_W ),        conv_std_logic_vector( FM+EP,ROMDATA_W ),        conv_std_logic_vector( FM+EP+DM,ROMDATA_W ),        conv_std_logic_vector( GP,ROMDATA_W ),        conv_std_logic_vector( GP+DM,ROMDATA_W ),        conv_std_logic_vector( GP+EP,ROMDATA_W ),        conv_std_logic_vector( GP+EP+DM,ROMDATA_W ),        conv_std_logic_vector( GP+FM,ROMDATA_W ),        conv_std_logic_vector( GP+FM+DM,ROMDATA_W ),        conv_std_logic_vector( GP+FM+EP,ROMDATA_W ),        conv_std_logic_vector( GP+FM+EP+DM,ROMDATA_W )        );  begin           process(clk)   begin    if clk = '1' and clk'event then 	  datao <= rom( CONV_INTEGER(UNSIGNED(addr)) );     end if;   end process;        end RTL;
library IEEE;    use IEEE.STD_LOGIC_1164.all;   use IEEE.STD_LOGIC_arith.all;   use WORK.MDCT_PKG.all;  entity ROME is    port(         addr         : in  STD_LOGIC_VECTOR(ROMADDR_W-1 downto 0);         clk          : in  STD_LOGIC;                 datao        : out STD_LOGIC_VECTOR(ROMDATA_W-1 downto 0)    );             end ROME;   architecture RTL of ROME is        type ROM_TYPE is array (0 to (2**ROMADDR_W)-1)              of STD_LOGIC_VECTOR(ROMDATA_W-1 downto 0);   constant rom : ROM_TYPE :=      (     (others => '0'),                      conv_std_logic_vector( AP,ROMDATA_W ),               conv_std_logic_vector( AP,ROMDATA_W ),               conv_std_logic_vector( AP+AP,ROMDATA_W ),            conv_std_logic_vector( AP,ROMDATA_W ),               conv_std_logic_vector( AP+AP,ROMDATA_W ),            conv_std_logic_vector( AP+AP,ROMDATA_W ),            conv_std_logic_vector( AP+AP+AP,ROMDATA_W ),         conv_std_logic_vector( AP,ROMDATA_W ),               conv_std_logic_vector( AP+AP,ROMDATA_W ),            conv_std_logic_vector( AP+AP,ROMDATA_W ),            conv_std_logic_vector( AP+AP+AP,ROMDATA_W ),         conv_std_logic_vector( AP+AP,ROMDATA_W ),            conv_std_logic_vector( AP+AP+AP,ROMDATA_W ),         conv_std_logic_vector( AP+AP+AP,ROMDATA_W ),         conv_std_logic_vector( AP+AP+AP+AP,ROMDATA_W ),        (others => '0'),                      conv_std_logic_vector( BM,ROMDATA_W ),               conv_std_logic_vector( CM,ROMDATA_W ),               conv_std_logic_vector( CM+BM,ROMDATA_W ),            conv_std_logic_vector( CP,ROMDATA_W ),               conv_std_logic_vector( CP+BM,ROMDATA_W ),            (others => '0'),                      conv_std_logic_vector( BM,ROMDATA_W ),               conv_std_logic_vector( BP,ROMDATA_W ),               (others => '0'),                      conv_std_logic_vector( BP+CM,ROMDATA_W ),            conv_std_logic_vector( CM,ROMDATA_W ),               conv_std_logic_vector( BP+CP,ROMDATA_W ),            conv_std_logic_vector( CP,ROMDATA_W ),               conv_std_logic_vector( BP,ROMDATA_W ),               (others => '0'),        (others => '0'),                      conv_std_logic_vector( AP,ROMDATA_W ),               conv_std_logic_vector( AM,ROMDATA_W ),               (others => '0'),                      conv_std_logic_vector( AM,ROMDATA_W ),               (others => '0'),                      conv_std_logic_vector( AM+AM,ROMDATA_W ),            conv_std_logic_vector( AM,ROMDATA_W ),               conv_std_logic_vector( AP,ROMDATA_W ),               conv_std_logic_vector( AP+AP,ROMDATA_W ),            (others => '0'),                      conv_std_logic_vector( AP,ROMDATA_W ),               (others => '0'),                      conv_std_logic_vector( AP,ROMDATA_W ),               conv_std_logic_vector( AM,ROMDATA_W ),               (others => '0'),        (others => '0'),                      conv_std_logic_vector( CM,ROMDATA_W ),               conv_std_logic_vector( BP,ROMDATA_W ),               conv_std_logic_vector( BP+CM,ROMDATA_W ),            conv_std_logic_vector( BM,ROMDATA_W ),               conv_std_logic_vector( BM+CM,ROMDATA_W ),            (others => '0'),                      conv_std_logic_vector( CM,ROMDATA_W ),               conv_std_logic_vector( CP,ROMDATA_W ),               (others => '0'),                      conv_std_logic_vector( CP+BP,ROMDATA_W ),            conv_std_logic_vector( BP,ROMDATA_W ),               conv_std_logic_vector( CP+BM,ROMDATA_W ),            conv_std_logic_vector( BM,ROMDATA_W ),               conv_std_logic_vector( CP,ROMDATA_W ),               (others => '0')      );                    begin        process(clk)   begin    if clk = '1' and clk'event then     datao <= rom(CONV_INTEGER(UNSIGNED(addr)) );     end if;   end process;          end RTL;
The constant values are AP:1448,BP:1892,CP:784,DP:2009,EP:1703,FP:1138,GP: 400,AM:-1448,BM:-1892,CM:-784,DM:-2009,EM:-1703,FM:-1138,GM:-400.
I run the testbench to see the output. However, I do not understand how they build the ROME and ROMO table. How they manage 6 bits address with the constant value? I try to write back the table with address and the constant values at a paper, but I still don't get it. As I know, they splits the constant into odd and even values and build the table. I really need help from anyone expert here http://www.edaboard.com/images/smilies/icon_sad.gif . Very appreciate your help. Thank in advance
    Hai Daixiwen,
    I use to_slv function to convert the floating point to std_logic_vector type. Btw, thanks for your helps :)
    You can use the same principle and do the conversion from constant float to integer by doing a multiplication in each assignment, but if you have some time I'd suggest to use the new VHDL fixed point signed type. Then you can directly use those values and your code will be a lot easier to read.
    This type isn't officially supported in Quartus yet, but you can use a compatibility library and then use the type in your VHDL files. Have a look at this thread (http://www.alteraforum.com/forum/showthread.php?t=36362) for more information.
    Hai Daixiwen,
    Actually I want to create a ROM table with 8 constant values. All the constant values are in fixed point number (0.123,0.871,-0.99,..etc). In the main project, an input of std_logic_vector (7 downto 0) is used as an address for the ROM. Out of the topic, how to convert the fixed point number to std_logic_vector? Thanks in advance
    How are those ROMs instantiated in the higher level component? If you want to write back a table with the input => output assignments in each ROM, you just need to read the data values in the order they are listed (and remember that (others => '0') means a data vector with all zeros). For example for ROMO:
    addr
    data
    000000
    0
    000001
    GP
    000010
    FP
    000011
    FP+GP
    000100
    EP
    000101
    EP+GP
    000110
    EP+FP
    000111
    EP+FP+GP
    001000
    DP
    001001
    DP+GP
    001010
    DP+FP
    001011
    DP+FP+GP
    001100
    DP+EP
    001101
    DP+EP+GP
    001110
    DP+EP+FP
    001111
    DP+EP+FP+GP
    010000
    0
    010001
    FM
    010010
    DM
    etc...
    That said, I think you could replace those ROMs by the actual arithmetic operations they are supposed to accelerate. The synthesizer should be smart enough to optimize this and I'm not sure that using a ROM block for that is actually a good optimization.
    --- Quote Start ---
    Ignorant question: why do you think to need to split the ROM in odd and even at all? For hardware processors, odd and even are used when e.g. two 8-bit ROMs are connected to a 16-bit databus. This won't be necessary in FPGA where you can define a 16-bit ROM directly.
    --- Quote End ---
    Hai FvM,
    Actually I get the code in open source and I don't know why the ROM is splits to odd and even. That is the exact question that I try to ask. I build the ROM table refer to the code, but I don't understand how they manage the input address with the constant value.
    However, how to build the ROM table if I have eight constant values that will be multiply with eight input data? Is it not necessary if I split the constant to two ROM table (4 constant each ROM)?.. Thanks in advance
    The question isn't clear. The ROM instances itself don't know about odd or even address, it's a matter how you connect address and data line externally, which isn't shown in your post.
    --- Quote Start ---
    I'm sorry you code is extremely difficult to read. Could you repost it with newlines? In any case, it seems to use the (bad) conv_std_logic_vector function a lot...
    --- Quote End ---
    Hai Daixiwen,
    Below is the code,hope you can help. Thanks in advance.
    -- 5:0
    -- 5:4 = select matrix row (1 out of 4)
    -- 3:0 = select precomputed MAC ( 1 out of 16)
    library IEEE;
    entity ROMO is
      port(
           clk          : in  STD_LOGIC;
    end ROMO;
           (others => '0'),
           (others => '0'),
           (others => '0'),
           (others => '0'),
    begin
      process(clk)
      begin
       end if;
      end process;
    end RTL;
    -- 5:0
    library IEEE;
    entity ROME is
      port(
           clk          : in  STD_LOGIC;
    end ROME;
        (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0'),
         (others => '0')
    begin
      process(clk)
      begin
       end if;
      end process;
    end RTL;
